Removing Front Subframe
I have been cleaning and prepping my 62 Skylark for painting. It looks like I can remove the entire front subframe with 3 -6 bolts. Is there any trick to this I may do this really get her clean. Any advice?
reebz- Posts : 49
Re: Removing Front Subframe
I meant to say font suspension not sub frame!!!
reebz- Posts : 49
Yep.
The following is gone or remove or disconnected: Steering shaft, motor, Trans, Wires, Brake lines. Anything I'm missing?
Is it as easy as it seems?
reebz- Posts : 49
should be a ground wire think that's it
I forgot that one. Thanks I think I'm going to take it off this weekend. Clean in up paint it and replace what looks worn. Thanks again
reebz- Posts : 49
"shameless post for Ben."
Ben at BCCP has a disk brake set up that's a breeze to install might want to check it out. Tell him Fred in Oklahoma sent you.
I would like to put 5 lug wheels on it with disc brakes. I'm not sure who to source for conversion.
reebz- Posts : 49
GM didn't change much through the years. I have 72 Skylark hubs on my car. The steering is our issue but I'm making a bracket for the caliper to mount to
YoungGun12- Posts : 60
Really! 72 Skylark hubs with 5 lug will fit 62 Skylark spindle that was built for 4. Thats crazy. Thanks
reebz- Posts : 49
» Front Subframe Bushings
» tools for removing a-arm
» 1962 Buick Special subframe bushings
» removing rear bumper- 62 special
» Removing Pinchweld molding on 62’ Skylark convertible
