1962 Buick Skylark Convertible
+5
Wailleur
cdnwillyg
9 posters
Page 6 of 7
Page 6 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: 1962 Buick Skylark Convertible
Thats exactly what I did...used wire wheel on the whole car...85 hours later it was down to bare metal and rust and fiberglass free.
troy noble- Posts : 66
Is that rust at the door corner? Going to replace it? I would cut there and take a bar to push the dent out, another way maybe is to cut in the center of the dent pull it out the weld the cut, if the metal is stretched welding might bring it back into place. As for the holes in the rear I'd cut that mess out and patch in a new piece, welding up holes like that and as they stretched it pulling it out your going to have a mess. (I know personally) btw great job so far.
The door corner is good just missed primer there. I couldn't get to the back of rocker, there is another floor piece there ( convertible thing??) So I went and built the Branford 4000 dent puller (lol) then attacked tabs and started to get the dent out. First I was pulling the tabs off, not enough weld on them, now I'm snapping Gr.8 bolts so started using an allen key??see how long that lasts. The rust on lower quarter, wheel lip and rear rocker area will all be cut and replaced. Thanks, here are a couple pics of the process i"m using not going to be fast but should get the job done on this 1/8" rocker!
rustywagon likes this post
Well today was the day the Skylark went out to be painted. I was going to change color but decided to go with factory Arctic White to keep it as close to original as possible. It will be single stage with two coats of clear to allow correction if needed. Can't wait but should be done by next week!!!!!
» 1962 buick skylark
» 1962 Red Skylark Convertible
» 1962 Buick Special Deluxe Convertible -- Trunk Help
Page 6 of 7
