New Carb or???
New Carb or???
'62 Special 215, the I looked at a straight up overhaul but frankly the Rochester is pretty worn out. Are there any Holley's or Edelbrocks that would work?
These motors don't need big CFMs so I thought I'd ask if anyone was running a bolt on?
Capt. B
Capt. B
Capt. B- Posts : 10
Re: New Carb or???
Edelbrock 1403 ( 500 cfm - e choke ) or 1404 ( 500 cfm manual choke ) are the consensus go to's if you want to move on from the 4GC.
I've got a 1403 on my car it is pretty much a bolt on. Seemed to add a lil pep over the 4GC as well. Might run a tad rich out of the box but E-brocks are very easy to make jet/metering rod changes and tune.
Other option ( if $$ allows ) would be to go with one of the packaged EFI units out there ( MSD, EZ EFI, FITECH ) but obviously this option will cost more and require more work as well.
» Carb Rebuild kits
» OEM AIR CLEANER w/ EDELBROCK CARB
» edelbrock manifold and carb swap
» F/S Carter AFB 9410 4 BBL. Carb.
» 4 Bbl. manifold and carb upgrade
