Buick 215 Timing Cover Question
Re: Buick 215 Timing Cover Question
Timing cover seals are available at Rock Auto...$6 FEL-PRO 15200 probably any auto store.
You might also consider switching over to a neoprene seal. It's possible with the v6, 350 & 455 so I'd think it's possible in this case too. I'd check with D & D engines ( Michigan ) or TA performance ( Arizona ). I'd think between the two someone would know for sure and be able to set you up with the right seal.
Hi,
My understanding is the original timing cover seal was a “rope” or material type impregnated with graphite, similar to the one fitted at the rear of the crank. The later replacement neoprene seals should work much better but make sure the sealing surface on the pulley is smooth and free of rust or pitting.
Won’t hurt to give it a light rub with some fine wet and dry rub paper soaked with oil to remove anything that could cut or damage the new seal.
And best to use some light grease or Vaseline on both the sealing surfaces when putting back together to give some initial lubrication. And check to make sure it is fitted right way round.
Just my two bobs worth
Rodney
Rodney
RodneySkylark- Posts : 8
Thanks for the info. Extremely helpful! I need to give these D&D guys a call.
Hoppy- Posts : 107
You might also contact Russ Martin at Centreville Auto Repair. Russ specialises in Nailhead Buick’s ( 364, 401, 425 ) for the senior cars but I understand he may do stuff for the PinHead V8 also. He certainly has good info there. Russ helped me out with a timing cover for my ‘63 Riviera a few years back.
Cheers
Rodney
Cheers
Rodney
» Timing gear cover
» Timing gear cover
» Timing gear cover & 4 bbl intake manifold
» Motor swap question: Want to put 350 Buick in 62 Skylark
» 1961 Buick Skylark Engine 215 V8 Question
» Timing gear cover
