Fuel pump help
Fuel pump help
Hi all, does anyone have a 63 skylark with factory AC, if so could you tell me where the fuel pump is located? I put an after market in my 63 and had to go with an electric fuel pump. any help would be appreciated. Thanks in advance! Gary in sunny AZ
gary- Posts : 50
Re: Fuel pump help
Well the mechanical fuel pump is located in the same place for all 61-63 with the aluminum V8 or iron V6. Directly below the distributor on the driver side of the front timing chain cover.
I have a blank cover over where mine used to live and replaced it with an electric Carter pump at the back near the tank. I keep a hidden switch and turn it off when I park it. If it gets stolen they will get about 1/8 a mile before it stalls out for lack of fuel.
Re: Fuel pump help
Yes I know where the mechanical fuel pump goes! I had to move mine when I put an aftermarket ac system in, I was wondering where they put the fuel pump on the original factory air system in a 63 skylark. The mechanical pump can't go where it is on a non ac car (I don't think). Also mine has a switch as well. Gary
gary- Posts : 50
Re: Fuel pump help
According to the manual:
If there are clearance problems, it may have a different length body or something. There is no mention of any differences in the manual. The pump has only one place to get to the eccentric to drive it and that is where it is located... Maybe very tight, but and standard one 'should' fit.
An AC Type HQ fuel pump is used on all engines. The pump assembly is mounted on the
right side of the timing chain cover in an inverted position, and the pump rocker arm is
actuated by an eccentric mounted on front side of the camshaft sprocket.
Re: Fuel pump help
Thank you very much, it would have to be a tight squeeze! Gary
gary- Posts : 50
» aftermarket fuel pump
» Fuel Injection Swap
» 1961 - 1963 Buick Special, Sklyalrk 215 v8 w/o ac ++ NEW ++ WAter Pump
» Oil pump gasket question-Need help
» Rochester 4 bbl carburetor fuel line size
