PST suspension parts - experiences
My experience... The lower A-Arm pivots worked fine. On the left, the upper pivot caps did not fit the OEM shaft and I had to re-use 2 of the best condition original ones. It got about 2 turns in and bound solid and would not pivot on the bearing surface (internal threads). If you get a 'upper shaft set' from them with the shaft and 2 pivots, it worked fine. I did this on my RF. The lower ball joints were the adjustable type and worked fine. The upper I put on the RF went in fine. The one (same part number and style) for the LF would not go in. It acted as if the diameter was too large. No amount of torque could get it more than 1/2 way in. Luckily the old one had no play and I just replaced the rubber boot and replaced it.
This note is just to urge you to trial fit all parts from them first and don't force anything.
In the end, I have a fully rebuilt steering and front suspension and new shocks over the past year, so things are in good shape!
Re: PST suspension parts - experiences
That's weird Keith - I didn't have the same experience at all. Everything went together as it should've for me. Guess mileage may vary...
» Parts - Emblems and maybe some body Parts
» parts and places for parts
» WHERE TO GET PARTS ?
» parts supplyer
» compatible parts
» parts supplyer
» compatible parts
