Aluminum Champion radiators
Page 3 of 9 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Re: Aluminum Champion radiators
Post by Bill on Wed Mar 09, 2016 1:54 am
Keith - fantastic job. You have made me a vertical happy person today! Way to go, and thanks for answering this question for all of us.
Post by Esasky's62Lark on Mon Mar 21, 2016 10:11 am
Gents,
My Champion Aluminum radiator is on it way and should be in my hands by Wednesday. I actually ordered it from Jeg's and they are shipping straight from manufacturer.
Anyhow, my plan is to remove the lower mounts and not use upper mount at all. I am going to tig weld aluminum L- brackets to the tanks and mount it straight to the rad support.
2 - 10" electric fans mounted to rad should do the trick to keep my little turbo V8 cool. :-)
Will keep you posted with progress and pictures.
Post by Bill on Mon Mar 21, 2016 1:50 pm
Sweet!
Post by Esasky's62Lark on Mon Mar 21, 2016 1:59 pm
Bill,
You planning on ordering one of these? From what I hear, they are pretty decent.
Post by Bill on Mon Mar 21, 2016 4:29 pm
Yes. I plan to order it on Friday. I see them on ebay with free shipping for $208 all day.
Post by Esasky's62Lark on Mon Mar 21, 2016 5:15 pm
Nice! I paid $227.00. Feel better ordering from somewhere I know has a reliable reputation.
Post by Bill on Mon Mar 21, 2016 6:11 pm
That's not too much more. Maybe I will go that route. Didn't know that they were that competitive.
Post by Bill on Mon Mar 21, 2016 6:14 pm
Also, can you provide me with whatever part you use to reduce the bottom hose? The outlet on the radiator is 1 3/4. I think it will be a new hose, but I would like to know what you come up with.
Post by Esasky's62Lark on Mon Mar 21, 2016 6:46 pm
Will definitely let you know Bill. My 62 has a 300 in it out of a LeSabre and I am pretty sure the water pump outlet is 1 3/4" so I may not have an issue.
Post by Bill on Mon Mar 21, 2016 8:49 pm
Even better!! I like the free solution!
Post by Esasky's62Lark on Tue Mar 22, 2016 10:32 am
Keith,
I try pal.
No, I am actually just planning on welding them on both sides of the tanks. There are already provisions on the rad support where the rad can be bolted directly to the support and no other bracketing should be necessary.
If I have to replace it, I just weld new L-brackets to the new rad and call it a day. :-)
Post by Bill on Thu Mar 24, 2016 8:03 am
Chris - Did you get it yet?
Post by Esasky's62Lark on Thu Mar 24, 2016 8:46 am
I did get the radiator. Just opened up the top of the box; didn't take it completely out. From what I saw so far, its is very well done. We are planning to start the install tonight.
I will be sure to provide pics!
Post by Esasky's62Lark on Fri Mar 25, 2016 8:47 am
Ok. Did a trail fit of the rad last night.
Had to grind a little of the core support to get the welds on the bottom tank to fit.
Radiator seems tall to me. Hood isn't on the car bit it definitely seems like it sits high. This is with the lower rad mounts unbolted from the rad support.
Lower hose port hits my oil filter. Oil filter relocation kit is in my future.
Other than that, rad is a nice piece. Didn't get a chance to take pictures.
Post by Esasky's62Lark on Fri Mar 25, 2016 8:56 am
Keith,
You went through the install. This thing clears the hood? It just seems like it's really tall. Is ur car a 63?
Don't the 63s have virtually no rake to front nose? More square?
Post by Esasky's62Lark on Fri Mar 25, 2016 9:12 am
That's the thing Keith, I don't have an original :-(.
Going to have to set it in there and lay the hood on.
Post by regal81455 on Fri Mar 25, 2016 10:31 am
Chris--
I'd measure for you but I think we determined you had the smaller of the two rads and thats why the one you got from kid442 doesn't fit for you, right?
Sorry to hear about the need for a filter relocate -- that's abit of a bummer but not a deal killer either.
Post by Esasky's62Lark on Fri Mar 25, 2016 10:33 am
Josh,
Yeah, that's exactly why pal.
It's cool. Was planning on moving it anyways to make more room for my DP off the turbo.
It's gonna be tight in this little engine bay...
Post by Bill on Fri Mar 25, 2016 1:09 pm
Chris- the filter problem is worth the 300 engine you have in there right? It likely won't be an issue for the stock 215 I hope.
