Front coil spring size
Post by YoungGun12 on Sat Aug 25, 2018 3:02 pm
Hey guys can anyone tell me the size of the front coil springs on a 62 special? Inside and outside diameter if you can. Thanks
YoungGun12
Re: Front coil spring size
Post by Alumin8 on Tue Sep 11, 2018 11:51 am
Just measured my '61 Skylark for you. (Rt-pass side, no air cond.)   Measures are not the best as the spring is on the car, but looks like the O.D. measures 4.3+", the I.D. measures 3.3+" and the spring coil diameter measures 0.55".  Could not do a coil height measure or pitch count with it on the car.   Keep in mind the coil is a little rusty, and the use of verniers on the car were not the easiest to set.   Should get you in the ball park.   Good luck.
Alumin8
Post by YoungGun12 on Wed Sep 19, 2018 10:05 am
Thank you very much for doing that
YoungGun12
Post by Alumin8 on Thu Sep 20, 2018 7:56 am
N.P.
Alumin8
