700R4 transmission swap
Post by Blue_Sky on Sat Sep 16, 2017 5:47 pm
I want to swap out the dual path transmission in a '62 Skylark (215 V8) with a 700R4. Has anyone done this? Expected issues are modifying transmission tunnel, moving transmission support cross-member, and length of front section of drive shaft.
Blue_Sky
Re: 700R4 transmission swap
Post by regal81455 on Mon Sep 18, 2017 9:50 am
You'll also need to get an adapter plate -- the 215 has a very unique engine to trans bolt pattern.  You can get the adapter from here...
http://aluminumv8.com/
No sense in keeping the old driveshaft when doing this swap convert over to a 1 pc. After modding the tunnel you shouldn't have any issues with this.
Keep us posted on the swap please!!
