Dual path filter ????
Post by Buwicked on Mon Aug 21, 2017 7:07 pm
Good evening to all of you
I just want to know about the dualpath tranny strainer/filter....
Do i have to install a new one when replacing oil??? If yes where do i order one ??
Can i just clean mine and put it back in with fresh oil???
Can i remove it completely and put the oil pan back with new oil with no filter at all ?
Any thoughts
Buwicked
Re: Dual path filter ????
Post by regal81455 on Wed Aug 23, 2017 3:34 pm
You should replace a filter with every trans fluid change - similar to changing your filter when changing the oil -- biggest difference is the length of time between changes -- most trans fluids last 50-75k miles unless they are overheated.
You could get by with just a fluid change but why?
Anyways, you can order the filter and pan gasket here...
http://www.fatsco.net/dual-path.html
DEFINITELY NO TO YOUR LAST QUESTION BTW....
Filter?
Post by Johnbain on Sat May 05, 2018 7:56 pm
I am in same boat. From the manual I don't see that it has a filter. If you find one let me know. I tore it apart to change seals and cannot find any filter.
Johnbain
