what I'm starting with
Page 1 of 2 1, 2  Next
Post by custom880 on Tue Aug 15, 2017 3:31 pm
Just thought I'd take a few pics so you could see the monster I'm starting with. Guess I should of taken these before I started but don't think pictures while I'm working.
does anyone have one of these sitting around for the drivers side, the hinge assy. for back door.
custom880
Re: what I'm starting with
Post by regal81455 on Thu Aug 17, 2017 7:18 am
Looks like you have your work cut out for you -- keep posting updates please!
Post by custom880 on Thu Aug 17, 2017 12:47 pm
worked on the pass fender today, by no means am I a pro just do this as a hobby to keep me outa the bars.
The bottom of the fender was rusted out, I made the bottom section with an anvil ball peen and vise. the rusty insert was cut from a trashed fender
another shot of the piece I made
Insert tack welded in, using a tig which I'm new to (self taught)but having a few problems and I did get some warping which just happen to be under the brace, got some of it out by sliding flat bar under brace and hitting the brace.
any ideas on what causes this, I'm thinking dirt or rust in the metal but then I'm not a pro so any help?
gona need a little bondo only a lot less than before. Wanted to fill the moulding holes but we're having freaky weather 95+ with humidity thats unnatural for this part of Ok.
custom880
Post by regal81455 on Thu Aug 17, 2017 1:51 pm
Looks good!! Everyone starts somewhere and I too use this as a way to stay out of bars ( and any other trouble for that matter )!!
Can you tell us what kind of tig welder you're using and the settings / rods, etc.. this might help us figure out what is causing your blow through although I've got almost no experience with TIG. Others might though.
Post by custom880 on Tue Aug 29, 2017 7:06 pm
filled the holes for the chrome on the pass fender today and stripped the rear quarter, tail gate.
turned the heat down so I didn't get warpage  or blow thru
finished product and a shameless plug for what I drive when I need to go fast
custom880
Post by regal81455 on Wed Aug 30, 2017 9:54 am
One step closer to havin' her on the road!! Smile Keep posting the pics please!
Post by custom880 on Sat Sep 16, 2017 3:33 pm
been busy just not posting but since its Saturday I have a bit of free time. Been spending the last few days stripping the parts car.
cutting that rear quarter out was a pain in the AS>>>>>>
engine out of parts car seems ok held antifreeze and turns broke one bolt in exhaust manifold luckily it was the other side than the bolt I broke in the engine in the wagon, yes did use heat just not enough I guess.
I also straightened out the driver quarter as much as possible with a portapower and a little luck. I'm going to cut out the worst damage and weld in the patch. The door seems match again so I'm happy.
had to cut out the inner fenderwell to have access to the sheet metal, thought I'd have to cut the outer wheelwell but it pushed and pulled back into shape while using the portapower.
next will be to cut and paste this into the mess.
I hung the donor doors on the pass. side and cleaned them up a bit. Have some rust on the lower sill and already cut patches out of the donor just waiting to weld them in. My wife is thinking about having me paint it gold only after a few of these, we make it ourselves.....
I'm hoping to change her mind.......you guys have a great day!
custom880
Post by regal81455 on Mon Sep 18, 2017 9:48 am
Lookin good bro -- keep up the good work and the good spirits flowin'! Smile
Post by custom880 on Mon Sep 18, 2017 4:22 pm
DISCLAIMER: I'm not a professional body or auto mechanic. I spent 37 years being a crewchief on c-5s for the government until health made me retire. Everything I do has been self taught. I know it isn't perfect and yes there will be bondo. I just thought I would post my progress so that maybe someone else could say......if that ole-fart can do it.....
My avatar was my first attempt at a ground up build. I found parts in fields around here and built a truck. I did everything from body to interior, only the machining was farmed out. I had a little over 7k in the truck when I lost it. I'm hoping on spending less on the wagon. I would rather take a car heading for the scrap yard and even if it takes some bondo, try to put it out on the road again.
Reason I'm posting this is someone stopped by and told me I was wasting my time while he nick-picked my work, at least I'm doing it myself I told him. My saving grace was when he looked at the trunk of my 880 and the way I put new metal in it. He said it wasn't original but didn't look bad. He then let it slip out that his 30k cuda's trunk had a repop trunk in it only they pop riveted it in while they restored his car.
I guess what I'm trying to say  I'm 59 and still trying new things so for all of you that have doubts about doing your own work....don't it may not be perfect yet when it's on the road you'll have the satisfaction of knowing it's all yours and you'll have a chunk of change for your next ride.
On a side note rt338b-----wish I had your talent!
custom880
Post by regal81455 on Mon Sep 18, 2017 8:13 pm
Screw what others think bud. You are not doing it for them, youre doing it for yourself. I can't stand the holier-than-thou crowd. I think youre doin a great job, keep it up. You have skills from what Ive seen and youre only going to get better by taking some chances along the way.
Post by custom880 on Mon Sep 25, 2017 4:56 pm
Been busy again cut more body parts off of donor, pressure washed the engine bay and suspension and found this.
does anyone know if manual and power center link are the same? Cars shows a rebuild....is that using your old one or parts they have in stock.
I also did a little planning.
Where the black markers are I'm going to cut and bend the metal so the master cylinder will sit straight. The cuts will be bigger than the support and I'll fill with overlapping metal to keep the reinforcement. I'll cut the petal mount and bend it to match the new angle and weld the same.
I'm going to cut the firewall alone this line, just a little straighter, and bring it out, boxing the whole area to the bump near master cylinder so I can have more room for the vintage air system.
the controls are close to the same size as the vertical controls for the vintage system. Going to have to modify the dash to look sort of factory, did the same thing on my 46.
guess that's it for now!
custom880
Post by regal81455 on Mon Sep 25, 2017 7:15 pm
Hard to tell but the centerlink looks pretty rough -- the rebuild kit is approx $190 and all you get is the bit's and pieces within the tube -- mine had one of the ball sockets splayed open, kinda looks like you maybe in the same boat -- I ended up buying the tube brand new -- it's a rare parts product and lists for approx $500 in most places but low and behold I stumbled upon this site and was able to get it for $365 + s/h!!
https://www.carpartsdiscount.com/catalog/buick~skylark~61.html?3594=2331
Beats trying to work with a questionable part and isn't nearly as tough to swallow!!
Post by custom880 on Fri Oct 13, 2017 5:26 pm
more cut and paste...
passenger rocker had these funny little holes
holes gone
same where the stainless mounts to for the carpet
before
after
front inner fender had rust as well
before
after
a little seam sealer for good measure, don't worry I'll clean it up more before paint
also took the front suspension out of parts car, anyone needing front drums I'll have 2 sets...going 5 lug disk brake
and my next tackle, already cut lower section out of parts car, its not as bad as it looks still needs a little metal added only a lot less than whats on the car
Some of you might think I'm nuts fixing a car so bad. I think that's the fun of it. I wouldn't be making it into a sedan delivery if it was in better shape. Leave the good cars for the restorers. (Ok I am nuts but having a blast)
custom880
Post by 62cutlassconvert on Fri Oct 13, 2017 6:33 pm
From the looks of your front suspension mount you have the early style bushings. I bought a pair of the side mounts for my car but turns out there are early and late ones, unfortunately the ones I got are early ones and I need late ones. If your interested in the ones I have send me a PM, I'd like to sell them. If you're not interested guess I'll ebay 'em.
Post by custom880 on Sat Nov 11, 2017 4:22 pm
Well slow day so I thought I'd get caught up. Been busy,
cleaned and por15 the engine bay, left the firewall clear since I have some modifying to do once I get the brake master cylinder.
fixed rear quarter
filled more holes and removed door handle on rear door
fixed some rust on the tail end of the wagon
made a forced air respirator
shop vac exhaust and it comes with a heepa filter.
last I primed the fenders a door and the body of my 880
I did the bodywork first on the 880 and have since found out that you can use the 2k epoxy primer first, to keep the metal from rusting under the bondo, then do the bodywork so I'm trying that out on the wagon. You'll see it here Very Happy
custom880
Post by custom880 on Tue Nov 28, 2017 5:47 pm
Just another update, spent a lot of time cutting and fitting new panels for where the windows once were.
I'm shooting for having the pass. side done by the middle of December.
I also cut an old trunk I had to make the new firewall. It should give me about 4 more inches to tuck the ac in under the dash. Doesn't sound like much yet every inch helps for interior room.
I think it's an improvement, cleans up the firewall nicely.
custom880
Post by custom880 on Mon Dec 18, 2017 4:46 pm
Well its past mid December and still not finished with the pass side. we haven't had rain for a while so I spend some time watering our grapes etc. this is what I have been doing.
welded the rear door closed and welding the panels in the windows.
I primed the area and I'm now doing a little bodywork.
I didn't like the way the pillar looked so I've been spending a bit of time on it.
Before, drivers side....
pass side after I've worked it. I didn't want to have it look like a 4 door welded up so this is what I did.
it was a pain and most of the body work is done on the pillar just didn't have the camera today.
I wouldn't mind any ideas, hints or suggestions on how the build is going. Everyone needs a little motivation from time to time.
Other things I've done is blast the front suspension and will be painting it as soon as my brake brakes arrive. Ben has been trying to find some different rear brake drums to work on the rear....Haven't gotten any parts so I can't say anything on the install yet..
BTW Happy Holidays to everyone watching this build
custom880
Post by Esasky's62Lark on Tue Dec 19, 2017 12:12 pm
Awesome progress sir! You are kicking ass on this car! Keep the updates coming!
Post by custom880 on Mon Jan 08, 2018 5:47 pm
Finally after a week of 20 degrees and below I've done a bit more work
started by cutting out the bottom of the drivers rear quarter since I noticed that the spears on the sedans are smaller than on the wagon. So I'm going to cut and section good for bad and hopefully I will be able to straighten the wagons spear enough to make it look good.
section from sedan next to whats left of the wagon that I cut out
and well now it's in place and tacked in.
Also did some more rust repair on the front area of rear quarter
and patched it up
filled in the area left open from wheel well install with a piece I made myself
finally the front, rear area on the quarter
for those still young enough a little advice...buy the tools you ever dream you might need before you get to the age that you say...well I'll make do. I wanted an english wheel and a few other metal shaping tools for years, I just can't see spending the money now even though I have and had needed them for years. done with my rant.. Ended up making this part with a hammer dolly vise and whatever else I could use. It's not perfect...It'll have to do
part welded in
found this while welding laying on a cold floor, next to be fixed,
I'm not going to finish welding the rear quarter till all the pieces are in place. I did however weld the inner fender well to the wheel well lip to try and keep integrity of the shape as much as possible since I have to cut and hack my way through the panel.
Hope everyone is enjoying the new year!!!!!!!
custom880
Post by troy noble on Fri Jan 26, 2018 1:26 pm
I'm in the process of disassembling a 62 Skylark 2 door hardtop. If you're looking for anything that might fit let me know 217-597-0000.
troy noble
Post by custom880 on Sun Feb 04, 2018 5:00 pm
Been a while yet again but I have been busy working on that quarter. It was a nightmare but I think I got it where its workable.
This is what it looked like
this is what  it ended up looking like
Have some hammer/dolly work and some shrinking to do yet its solid once again.
few more shots
I tell you it was a job since I had to cut and paste several different pieces. Originally I was going to use the whole quarter out of the parts car then I realized that the "spears" where different sizes and the best I can figure is they had different dies for the wagons and the sedans.
I made it work anyways.
custom880
Post by regal81455 on Thu Feb 08, 2018 10:57 am
You're making incredible progress bud! It looks great -- keep'm coming -- going to be a very nice, solid car when you're done!
Post by custom880 on Thu Mar 29, 2018 5:27 pm
Sorry not much to post. ordered front suspension kit. brakes and rear axles should be here next week from BCCP-Ben's a great guy to work with. Also a bunch of stuff from summit.
As for the wagon just been doing bodywork. have both sides done, well good enough until I start doing the finish sanding.
working on the roof now only three dents, two of which are already removed, last one on the rear by the hinges.
trying to get as much of the bodywork completed before summer sets in then it gets to hot here to do much bondo work. Still have the rear door to straighten out and strip the hood.I'll be starting to modify the interior next, retractable seatbelts, a/c etc.  Hoping on spraying the front end and door jams etc. soon with single stage so I can get her up on her wheels again. Anyone run crager s/s wheels, any pics?
custom880
Post by custom880 on Thu Jun 07, 2018 7:12 pm
worked on the firewall to have the master cylinder sit level. Cut the firewall and moved the bottom of the mount area out a bit
made a panel for the bottom that I bent and would over lap the original metal for added strength.
well maybe pics later having problems with downloading them. seem to all come out way oversized and blurry. Anyone else having problems with "host an image"
piece I made to fill the bottom of cut
inside shot with pilot holes since it was easier to cut in the inside.
top view everything clears.
installed after welding
had to cut and angle the pedal mount. seems to keep the same angle when completed.
job done.
custom880
update
Post by custom880 on Mon Aug 13, 2018 6:34 pm
delete
custom880
