Barrel nuts/clips
Barrel nuts/clips
Post by StageCat on Tue Jul 11, 2017 7:18 am
Have '62 Special, gonna install new door weather strip, thought that these would be pretty common but nooo.
I can't find any, does anyone have any sources for the nylon/plastic barrel nuts around lower portion of door frame, that the weather strip pins push into ?
The hole in door is 5/16".....the pin on the door seal is 5/32", any help appreciated.....thanks.
Re: Barrel nuts/clips
Post by regal81455 on Tue Jul 11, 2017 7:32 am
I feel pretty dumb - not really sure what it is your after -- did you check with Steele Rubber or Ames Performance? -- any way you can post a link or picture to give me some idea - I might be able to help then.
Post by 62cutlassconvert on Tue Jul 11, 2017 9:26 am
I bought Steele Rubber door weatherstrip and they came with the weatherstip. If you already have strip without it maybe they would sell you some, or I have a few left over if you don't need a bunch of them I could take a look and see what I have.
Post by StageCat on Tue Jul 11, 2017 4:38 pm
Thanks guys, I got Steele too but no clips. I will call in AM, I will ck Ames....Thanks
Post by regal81455 on Wed Jul 12, 2017 7:25 am
Np! Please be sure to report back on your findings so future hunts for other members can be minimized! Tx!
Post by StageCat on Wed Jul 12, 2017 9:21 am
Ok, here's the down low. Nothing listed at Ames, went back to Steele as 62cutlass said he received some with a kit. Going thru Skylark kits came up with this page
http://www.steelerubber.com/door-weatherstrip-50-0339-72   go to exploded view of parts and look at what they call socket(bingo) part#70-0812-98 They do not list that number online, called them and they are .30 each, so 34 is $10.20. I ordered 36 just because, it appears these sockets are just with Skylark kits, not the lowly Special.......
Post by regal81455 on Wed Jul 12, 2017 9:24 am
Good deal!! Glad you were able to find what you were after! Additionally, thank you for following up! This may save someone a boatload of time down the line!
