TIE ROD END
TIE ROD END
This past weekend I managed to get sometime to inspect the steering components on my car. The passenger side outer tie-rod wasn't loose at the spindle or the steering tube connections BUT I was able to move it in the direction of the front to back of the car. ( IE I was able to rock it while it was affixed at both ends ). I know its essentially a ball joint in the steering tube but how tight should it be? The driver side did not share the same amount of movement. Any thoughts? May have to post a video to further explain if this isn't clear enough.
TIA
TIA
