Barrel nuts/clips
Barrel nuts/clips
Have '62 Special, gonna install new door weather strip, thought that these would be pretty common but nooo.
I can't find any, does anyone have any sources for the nylon/plastic barrel nuts around lower portion of door frame, that the weather strip pins push into ?
The hole in door is 5/16".....the pin on the door seal is 5/32", any help appreciated.....thanks.
Re: Barrel nuts/clips
I feel pretty dumb - not really sure what it is your after -- did you check with Steele Rubber or Ames Performance? -- any way you can post a link or picture to give me some idea - I might be able to help then.
I bought Steele Rubber door weatherstrip and they came with the weatherstip. If you already have strip without it maybe they would sell you some, or I have a few left over if you don't need a bunch of them I could take a look and see what I have.
Thanks guys, I got Steele too but no clips. I will call in AM, I will ck Ames....Thanks
Np! Please be sure to report back on your findings so future hunts for other members can be minimized! Tx!
Ok, here's the down low. Nothing listed at Ames, went back to Steele as 62cutlass said he received some with a kit. Going thru Skylark kits came up with this page
http://www.steelerubber.com/door-weatherstrip-50-0339-72 go to exploded view of parts and look at what they call socket(bingo) part#70-0812-98 They do not list that number online, called them and they are .30 each, so 34 is $10.20. I ordered 36 just because, it appears these sockets are just with Skylark kits, not the lowly Special.......
Good deal!! Glad you were able to find what you were after! Additionally, thank you for following up! This may save someone a boatload of time down the line!
» hood trim clips
» hood molding clips for 61 special
» spring clips? dodads that keep the door in place
» 62 special deluxe TRUNK lid chrome trim fastener / clips
